  The meeting place for Ducati Multistrada owners
Search the forums (advanced)
 Navigation
  Photo albums
  Links
  Downloads
  Multistrada Wiki
  About us
Username:
Password:
 Log me on automatically each visit
Problems signing in?
Forum index -   Wanna buy: Small parts ...?!
Post new topicReply to topic View previous topic :: View next topic
DJMcSpeed
MTS: 2007 1100S (Black)
PostPosted: Fri Jun 10, 2016 1:30 pm Reply with quote
Hello,
If you're like me, you're frustrated with the fact that you must purchase expensive assembles, rather than the small parts that are needed. I get that Ducati is supporting their dealer service departments, but, case in point, the clutch lever is sold with the swivel pin and screw in plunger that actuates the clutch. In my case I can't separate the pin from the plunger to use with new levers, but must purchase a new lever at $100.00 +-, just to get two small parts ... and a spare lever.
Is anyway aware of a solution for this?
DJ
MI-USA
View user's profileSend private message Top
DJMcSpeed
PostPosted: Fri Jun 10, 2016 1:34 pm Reply with quote
Sorry, the bike is a 2007 Multistrada 1100s, and the part No. is 626.4.034.1A (swivel pin and plunger not shown
Link to ebay photograph that does show small parts: http://www.ebay.com/itm/Ducati-Brembo-Cl...dds&vxp=mtr
Thanks in advance,
DJ
DJ
MI-USA
Prestob
MTS: 2005 1000S DS (Red)
PostPosted: Fri Jun 10, 2016 1:56 pm Reply with quote
Funny I'm in the same position but found an answer over at
http://www.webbikeworld.com/t2/pazzo/adjustable-levers.htm
Ducati put glue on the plunger but burn it off and you'll get to a small screw that can be removed to allow the plunger to unscrew. It is on my todo list tonight.
ben[/url]
DJMcSpeed
PostPosted: Fri Jun 10, 2016 2:10 pm Reply with quote
Beautiful! Thanks much!
I was hoping someone like me that keeps all those small parts, might have one, but this will work too!
DJ
MI-USA
Mattel
MTS: 2012 1200S PP (Corse)
PostPosted: Sat Jun 11, 2016 11:14 am Reply with quote
I dont think you are correct. I have a Pazzio and it still requires the part that he is missing.
See down the page
" Parts and Pins
Here are the parts after removal from the OE adjustable lever. The 1.5 mm set screw is on the left, with the scarred up pin in the center and the rotating pin on the right. The 1.5 mm hex wrench is shown to illustrate the small size of these parts.
I used blue Loctite on these parts on reassembly, and I hope it holds everything together as well as the semi-permanent Ducati sealer."
You still need to locate that pin and plunger. Sorry....
The twisted sisters... 07 1100s, 08 1100s & 12PP Angry Duck
ATGATT+AIR!!!
Display posts from previous:    All times are
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
