DJMcSpeed MTS: 07 1100S (Black)
Posted: Fri Jun 10, 2016 1:30 pm |
Hello,
If you're like me, you're frustrated with the fact that you must purchase expensive assembles, rather than the small parts that are needed. I get that Ducati is supporting their dealer service departments, but, case in point, the clutch lever is sold with the swivel pin and screw in plunger that actuates the clutch. In my case I can't separate the pin from the plunger to use with new levers, but must purchase a new lever at $100.00 +-, just to get two small parts ... and a spare lever.
Is anyway aware of a solution for this? |
_________________ DJ
MI-USA |
Posted: Fri Jun 10, 2016 1:34 pm |
Sorry, the bike is a 2007 Multistrada 1100s, and the part No. is 626.4.034.1A (swivel pin and plunger not shown
Link to ebay photograph that does show small parts: http://www.ebay.com/itm/Ducati-Brembo-Cl...dds&vxp=mtr
Thanks in advance,
DJ |
MI-USA |
Prestob MTS: 05 1000S DS (Red)
Posted: Fri Jun 10, 2016 1:56 pm |
Funny I'm in the same position but found an answer over at
http://www.webbikeworld.com/t2/pazzo/adjustable-levers.htm
Ducati put glue on the plunger but burn it off and you'll get to a small screw that can be removed to allow the plunger to unscrew. It is on my todo list tonight.
ben[/url] |
Posted: Fri Jun 10, 2016 2:10 pm |
Beautiful! Thanks much!
I was hoping someone like me that keeps all those small parts, might have one, but this will work too! |
MI-USA |
Mattel MTS: 12 1200S PP (Corse)
Posted: Sat Jun 11, 2016 11:14 am |
I dont think you are correct. I have a Pazzio and it still requires the part that he is missing.
See down the page
" Parts and Pins
Here are the parts after removal from the OE adjustable lever. The 1.5 mm set screw is on the left, with the scarred up pin in the center and the rotating pin on the right. The 1.5 mm hex wrench is shown to illustrate the small size of these parts.
I used blue Loctite on these parts on reassembly, and I hope it holds everything together as well as the semi-permanent Ducati sealer."
You still need to locate that pin and plunger. Sorry.... |
_________________ The twisted sisters... 07 1100s, 08 1100s & 12PP Angry Duck
ATGATT+AIR!!! |
