Forum index -   Wanna buy: Cold Start Lurch in 1st Gear - 2006 620
nels
MTS: Not specified
PostPosted: Mon May 08, 2017 6:42 pm Reply with quote
Hi All,
I am new to forum. I am looking at buying a 2006 620 w/ 7900 miles.
Question about a service item reported by the seller:
The seller reports that the bike will sometimes lurch forward if he attempts a cold start in first gear. He reports that his buddy says it is likely 'due to cold primary fluid.'
I searched the forum and around the web and couldn't find reports of the same problem.
Can any of you experts out there help diagnose?
All my best,
Nels
DMT
MTS: 2004 1000 DS (Gray)
PostPosted: Mon May 08, 2017 11:00 pm Reply with quote
It sounds to me like the wet clutch plates are sticking together (fibers to steels). This can happen if the moto sits without the transmission being used for some time. However, some motor oils will also cause this problem.
I would also double-check the free-play at the hydraulic clutch lever tip.
It should be set to 10mm.
View user's profileSend private messageVisit poster's website Top
46
MTS: 2006 620 (Red)
PostPosted: Tue May 09, 2017 2:35 am Reply with quote
I bought mine used with unknown oil type and time it sat in the previous owner's garage . I put Castrol Actevo synthetic oil and the issue went away.
nels
MTS: Not specified
PostPosted: Tue May 16, 2017 2:17 pm Reply with quote
Thanks for the info, guys, going to check out this bike, hope to join the ranks soon.
