Main.ClutchActuatorPinAdjustment History
Show minor edits - Show changes to output
Sat Aug 02, 2008 11:19 PM
by Scrambles - How to adjust the clutch actuator pin at the lever
Added lines 1-23:
[quote="ducatidesigns"]Adjusting the little plunger screw in the lever to get more stroke, preventing fluid return to the reservoir, can wreck things as well.[/quote]
[quote="Scrambles"]Paul,
I recently installed a CRG clutch lever, and had to adjust that pin. Can you describe the right way to adjust it to avoid what you describe above?[/quote]
[quote="ducatidesigns"]Conservatively is probably the best advice. Turning it in moves the engagement point out, lifting the clutch pressure plate higher. I've had success screwing it in one turn or less (after picking out that crusty gunk Ducati seals it with) without a problem, and that adds quite a bit of lift to the clutch. If you go too far, the master piston can block the fluid return port when you release the clutch. Without a return path, fluid pressure in the line will build up, especially when the fluid and air in the circuit get hot. This can cause the clutch to slip and increase wear on the pushrod, throwout bearing and slave cylinder. Mild slipping that you don't necessarily notice will wear out your clutch quickly.
One way to tell its working right is to remove the reservoir cap and look carefully for return flow (a little squirt near the piston) when you slowly release the lever. Wear glasses, in case you let it go too fast!
Hope that helps!
pg[/quote]
[quote="Scrambles"]Thanks Paul. So, it seems as long as there is some play left it should be OK, but the key is whether or not the fluid is returning (the squirt). Is that right?[/quote]
[quote="ducatidesigns"]Exactly. You don't want constant pressure on the rod to disengage the clutch, so you want the fluid to return to the reservoir quickly. I ship a lot of 30mm MPL slave cylinders, and it sometimes takes 1/2 turn or so (from factory setting) to get good disengagement, never more. Be sure to bleed things well before you start; any air in the system just compounds problems.
Ciao!
pg
DD[/quote]
