  The meeting place for Ducati Multistrada owners
Search the Wiki
 Navigation
   Photo albums
   Links
   Downloads
   Multistrada Wiki
   About us
Username:
Password:
 Log me on automatically each visit
Problems signing in?
  Diagnostic Software
Main.DiagnosticSoftware History
Hide minor edits - Show changes to markup
Sun Sep 09, 2018 07:30 AM by rickityrick -
Sun Sep 09, 2018 07:23 AM by rickityrick -
Changed line 21 from:
 NEVER connect pos and neg round wrong way!!
to:
Changed lines 19-23 from:
Last words, never connect pos and neg round wrong way!! Always do a lead connection test before trying anything else, it's on the software (Connection test) Tab
to:
LAST WORDS
ALWAYS do a lead connection test before trying anything else, it's on the software (Connection test) Tab
Sat Dec 09, 2017 08:41 PM by rickityrick -
Sat Dec 09, 2017 08:40 PM by rickityrick -
Changed line 13 from:
The Software is FREE at http://jpdiag.ackress.com To get your licence follow the instructions to register your Ecu, then you will be able to use most of the program, Including resetting of service icon.
to:
The Software is FREE at http://jpdiag.akress.com To get your licence follow the instructions to register your Ecu, then you will be able to use most of the program, Including resetting of service icon.
Sat Dec 09, 2017 08:37 PM by rickityrick -
The Software is FREE at http://jpl250rs.perso.sfr.fr/ To get your licence follow the instructions to register your Ecu, then you will be able to use most of the program, Including resetting of service icon.
to:
Sat Oct 24, 2015 09:41 AM by rickityrick -
Changed lines 1-2 from:
Lots of questions on the forum re Diag, so I have made a short video. http://vimeo.com/93751906 you will need to use the following password to view, multistradads1000
to:
Lots of questions on the forum re Diag and the 5AM and 59AM ECUs
Changed lines 15-20 from:
To change Maps and virginise is charged for, contact JP. I have used the change map service to good effect so can confirm that it works well.
Also a program to tension belts as per mathesis tester is available free too. A cheap microphone is needed. I have also used this to good effect.
Do take time to read up everthing on JP's site.
to:
Do take time to read up everthing on JP's site. Also try Guzzidiag where instructions on re flashing are available.
Changed line 19 from:
to:
Mon Jun 16, 2014 08:03 PM by rickityrick -
Added lines 24-25:
Rick
Tue May 27, 2014 05:06 PM by rickityrick - Reset service icon
The Software is FREE at http://jpl250rs.perso.sfr.fr/ To get your licence follow the instructions to register your Ecu, then you will be able to use most of the program.
to:
Sun May 04, 2014 07:17 AM by rickityrick - added a few points
Changed lines 13-14 from:
to:
Added lines 22-23:
Sat May 03, 2014 07:05 PM by rickityrick - Software to reset service light and lots more for Mk 1 Multis
Sat May 03, 2014 07:02 PM by rickityrick - How to setup Diag for Mk1 Multis
Added lines 1-18:
Leads are found on ebay Two are required a blue one like this;--
 VAG GROUP USB COM PORT OBD2 II KKL ECU DIAGNOSTIC CABLE LEAD VCDS-LITE 409   DO NOT USE ANY SOFTWARE THAT COMES WITH THIS LEAD
Instead download the correct driver from JP's site.
and one like this;--
	 Fiat 3 pin OBD1 OBDI to OBD2 OBDII Convertor Connector Auto Scanner OBD Lead with flying +and- connectors
These are around £20 the pair.
Remember that you play with your ECU at your own risk. Please don't fry it by not following JPs advice.
