Main.ErrorCodes History
Hide minor edits - Show changes to markup
Sun Aug 17, 2014 10:56 AM
by multi61 -
Sun Aug 17, 2014 10:55 AM
by multi61 -
Wed Jul 10, 2013 11:10 AM
by ducatisti7 - e0.2 Horizontal cylinder coil short-circuit to ground\\
Mon Sep 26, 2011 03:40 PM
by niteridrzcycles - than - then
Changed line 2 from:
When the EOBD light (bottom right, amber light) comes on after turning on the ignition, the computer has diagnosed a problem somewhere on the bike. To display what is wrong: turn off the ignition, press and hold the "A" button and turn the ignition back on. Than release the "A" button. The main display now shows "EFI", and the smaller display shows the error code.
to:
When the EOBD light (bottom right, amber light) comes on after turning on the ignition, the computer has diagnosed a problem somewhere on the bike. To display what is wrong: turn off the ignition, press and hold the "A" button and turn the ignition back on. Then release the "A" button. The main display now shows "EFI", and the smaller display shows the error code.
Sat Dec 04, 2010 05:27 PM
by achilleasds -
Wed Mar 17, 2010 07:33 AM
by noahspurrier -
When the EOBD light (bottom right, amber light) comes on after turing on the ignition, the computer has diagnosed a problem somewhere on the bike. To display what is wrong: turn off the ignition, press and hold the "A" button and turn the ignition back on. Than release the "A" button. The main display now shows "EFI", and the smaller display shows the error code.
to:
Fri Jan 08, 2010 07:35 PM
by alephnull - spelling corrections
Changed lines 7-8 from:
1.1 Throtlle Position Sensor (TPS) short-circuit to battery +
1.2 Throtlle Position Sensor (TPS) short-circuit to ground\\
to:
1.1 Throttle Position Sensor (TPS) short-circuit to battery +
1.2 Throttle Position Sensor (TPS) short-circuit to ground\\
