Specifications 1000 |
Main.Specifications1000 History
Hide minor edits - Show changes to markup
Thu Jan 13, 2011 01:42 PM
by DharmaChappell -
Added lines 18-19:
(:cellnr:)Charging System
(:cell:)Output-520 Watts
Fri Jan 09, 2009 08:09 PM
by Admiral Nelson -
Changed line 98 from:
(:cell:)Red, metallic gray and black (1000DS)
to:
(:cell:)Red, Silver and black (1000DS)
Sun Nov 16, 2008 10:38 AM
by mark lear -
Thu Aug 28, 2008 02:15 AM
by cab713 - magazine mispelled
Changed line 31 from:
(:cell:)210 Km/h (as measured by Motorrad magazin)
to:
(:cell:)210 Km/h (as measured by Motorrad magazine)
Sun Jul 13, 2008 04:54 PM
by LBC MTS -
Changed lines 50-51 from:
(:cellnr:)Head angle, steering/turning angle (on each side), trail
(:cell:)24 degrees, 35 degrees, (92 mm per owner's manual, 109mm per service manual)
to:
(:cell:)24 degrees
(:cellnr:)Steering/turning angle
(:cell:)35 degrees on each side of center
(:cellnr:)Trail
(:cell:)92 mm per owner's manual, 109 mm per service manual
Sun Jul 13, 2008 04:43 PM
by LBC MTS -
Changed line 39 from:
(:cell:)Hydrolic operated dry multiplate
to:
(:cell:)Hydraulic operated dry multiplate
(:cellnr:)Head angle, rake
(:cell:)24 degrees, 99mm
to:
Changed line 60 from:
(:cell:)165mm front, 141mm rear
to:
(:cell:)165 mm front, 141 mm rear
Changed line 62 from:
(:cell:)Double 320mm semi floating centreless disks, 4-piston Brembo "Serie oro" calipers
to:
(:cell:)Double 320 mm semi floating centreless disks, 4-piston Brembo "Serie oro" calipers
Changed line 66 from:
(:cell:)Cast aluminum, 5 spoke with extended hub front (3.50 x 17), 6 spoke rear (5.50 x 17)
to:
(:cell:)Cast aluminum, 6 spoke with extended hub front (3.50 x 17), 5 spoke rear (5.50 x 17)
Sun Jul 13, 2008 04:31 PM
by LBC MTS - spelling
Changed line 9 from:
(:cell:)Single overhead camshafts (belt driven), two valves per cilinder, desmodromic valve actuation
to:
(:cell:)Single overhead camshafts (belt driven), two valves per cylinder, desmodromic valve actuation
Changed line 17 from:
(:cell:)Electronic, two spark plugs per cilinder
to:
(:cell:)Electronic, two spark plugs per cylinder
Changed line 21 from:
(:cell:)Two into one with 3-way catalyc converter (non-catalytic on USA version)
to:
(:cell:)Two into one with 3-way catalytic converter (non-catalytic on USA version)
(:cell:)Cast aluminium, 5 spoke with extended hub front (3.50 x 17), 6 spoke rear (5.50 x 17)
to:
Changed line 92 from:
(:cell:)Analog rev counter, LCD display with tachometer (kmh and mph), oil temperature, clock, trip meter, fuel level (litres and kilometres remaining), fuel consumtion, average speed, scheduled maintainance warning. Warning lights for jiffystand, oil pressure, low fuel, high beam, injection and indicators.
to:
(:cell:)Analog rev counter, LCD display with tachometer (kmh and mph), oil temperature, clock, trip meter, fuel level (litres and kilometres remaining), fuel consumption, average speed, scheduled maintainance warning. Warning lights for jiffystand, oil pressure, low fuel, high beam, injection and indicators.
Changed line 99 from:
(:cell:)Single key system with transponder (immobilizer), ignition swith with integrated steering lock, helmet lock.
to:
(:cell:)Single key system with transponder (immobilizer), ignition switch with integrated steering lock, helmet lock.
