Specifications 1100 |
Main.Specifications1100 History
Show minor edits - Show changes to markup
Tue May 31, 2016 06:32 PM
by canyonchaser -
Changed line 57 from:
to:
Tue May 31, 2016 06:30 PM
by canyonchaser -
Deleted line 51:
Deleted line 53:
Deleted line 55:
Deleted lines 57-59:
by canyonchaser -
Changed lines 52-53 from:
(:cellnr:)Head angle, rake
(:cell:)24 degrees, 99mm
to:
(:cell:)24 degrees
(:cellnr:)Steering Angle
(:cell:)35 degrees
(:cellnr:)Trail
(:cell:)92mm
Sat Jan 29, 2011 05:15 AM
by Hotcorner -
Changed line 96 from:
(:cell:)Analog rev counter, LCD display with tachometer (kmh and mph), oil temperature, clock, trip meter, fuel level (litres and kilometres remaining), fuel consumtion, average speed, scheduled maintainance warning. Warning lights for jiffystand, oil pressure, low fuel, high beam, injection and indicators.
to:
(:cell:)Analog rev counter, LCD display with tachometer (kmh and mph), oil temperature, clock, trip meter, fuel level (litres and kilometres remaining), fuel consumption, average speed, scheduled maintenance warning. Warning lights for jiffystand, oil pressure, low fuel, high beam, injection and indicators.
Changed line 103 from:
(:cell:)Single key system with transponder (immobilizer), ignition swith with integrated steering lock, helmet lock.
to:
(:cell:)Single key system with transponder (immobilizer), ignition switch with integrated steering lock, helmet lock.
Thu Jan 27, 2011 05:39 PM
by DharmaChappell -
Changed line 45 from:
(:cell:)O-ring chain (525pitch, 104" length), ratio 2.80 (15 teeth front, 42 teeth rear sprocket)
to:
(:cell:)O-ring chain (525 pitch, 104" length), ratio 2.80 (15 teeth front, 42 teeth rear sprocket)
by DharmaChappell -
(:cell:)O-ring chain, ratio 2.80 (15 teeth front, 42 teeth rear sprocket)
to:
Thu Jan 27, 2011 05:30 PM
by DharmaChappell -
Changed line 31 from:
(:cell:)10.5 Kgm @ 4750 rpm
to:
(:cell:)10.5 Kgm (75.98 Lb - Ft)@ 4750 rpm
Thu Jan 13, 2011 01:41 PM
by DharmaChappell -
Changed line 18 from:
(:cellnr:)Charging System Output-520 Watts
to:
Thu Jan 13, 2011 01:40 PM
by DharmaChappell -
Added line 19:
Thu Jan 13, 2011 01:39 PM
by DharmaChappell -
(:cell:)Charging System Output-520 Watts
to:
Thu Jan 13, 2011 01:38 PM
by DharmaChappell -
Added line 18:
Thu Aug 12, 2010 04:27 AM
by DharmaChappell -
Changed line 99 from:
to:
Red, Black, White (1100S)
Wed Jul 09, 2008 07:51 PM
by JJW -
Changed line 39 from:
(:cell:)Hydrolic operated wet multiplate
to:
(:cell:)Hydraulic operated wet multiplate
Changed line 101 from:
(:cell:)Storage space in the fairing and under passenger seat, electronic headlight adjustment, tool set, indicators integrated in rearview mirrors.
to:
(:cell:)Storage space in the fairing and under passenger seat, tool set, indicators integrated in rearview mirrors.
