Wanna buy » 2007 mts1100 wiring harness/loom wanted
multimongrel
hi all
Looking for a 2007 mts1100 wiring harness/loom in the u.k. preferably
Gregski
can I just ask what terrible happened to the bike that you need an whole harness :think: :think:
Nie Ma Boga Jest Motór
multimongrel
Cant resolve an ongoing start issue.
No spark on vertical cylinder during start up.
If the engine does catch then it runs well.
Had 2 new ecu's
Crank sensor changed.
Coils , plugs and leads changed.
multigatto
I have :
from MTS 1100
On sell
luckybum
Here's a harness available in the US:
http://www.rubbersideup.com/servlet/the ... 0-S/Detail
Luckybum
rickityrick
multimongrel wrote:Cant resolve an ongoing start issue.
Had 2 new ecu's
Not trying to teach you to suck eggs but............ no mention of battery check? also check ground on front of engine for corrosion. some of us use 2 grounds, gets the amps to the starter more cleanly.
You mention changing pretty much everything to do with ignition, so not many options left. Think if wiring problem, then why does she run sweet on 2 after starting.
A very slightly, and I mean slightly, low battery on these big twins will cause weak or no spark, furthest from coils 1st i.e. vertical. All starting effort is put into turning engine at the expense of sparking up the plugs.
Many others on here will have experienced this, some refuse to believe, saying their battery turns the engine fine and shows 12.5 volts. Then they try a known good battery.
You may have done the above already. If so pls ignore my ramblings.
Rick
Yes, battery and earth (-) is just as important as (+)
It has to have a complete circuit to work.
