Wanna buy » source for windscreen?
luckybum
I'm in the process of purchasing an '06 1000DS and it has this windscreen mounted. I like the screen but it needs replacement and I haven't been able to find one like it. It's marked Ducati along one edge and eliminates the body colored trim at the base the stock screen has. Here's a link to a photo of it.
https://picasaweb.google.com/rdm1946/Mo ... 4295951442
Thanks!
Luckybum
desertdog
Discontinued item from DP. Good luck finding one available.
luckybum
Oh well, I figured as much. At least it comes with a centerstand!
OceanMt_InlandSea
2009 1100S (Black)
.....so I take you you don't want to sell the center stand?
.....if you change you mind, let me know.
Pretty Dogged: 2007 BMW F650Dakar, 2009 MTS1100S
http://s737.photobucket.com/user/OceanMtnSea/library/
luckybum
After browsing the different forums on this site it appears it would be unwise to do so.............
jrt
2011 1200S (Red)
Don't know if they would help, but you might contact air tech:
http://www.airtech-streamlining.com/
They make a wide variety of fairings/windscreens.
No connection with them- it just popped into my head.
Good luck.
luckybum
Thanks for the link. I didn't find anything on the site that would work however. I'm going to try to repair the DP shield. It just has stress fractures around the mounting points. I have the stock shield assembly if that doesn't work.
Luckybum
yoseffby
I'd be interested in buying the alternate screen, even if its broken....
kuyohtay
My recommendation is Zero Gravity as direct fit replacement and slight upgrade. Smoked colors, progressively larger. CalSci would be a great option for further size and coverage upgrades. There are others, but these are most cost effective and aesthetically / functionally correct.
I have the ZG touring light smoke color. $70.00, perfect fitment and easy to do. Tape the end of your allen key so as not to "turn and scratch!"
Ed. :mrgreen:
If my ears ain't bleeding, it's not loud enough.
Fly Albatross, fly!
luckybum
Yes, the ZG touring is my backup plan. However, repairs on the DP have gone well so it looks like I'll be able to enjoy it for awhile yet. Thanks for the input.
Luckybum
desertdog
What did your repairs consist of? Mine has the same cracks.
luckybum
The cracks were too numerous to drill holes at the end of each one so I roughed up the back surface with fine sandpaper and applied IPS Weld-On #16 clear thickened acrylic sheet cement in a heavy bead over each crack. After allowing it to dry overnight I re-painted the areas I had worked on. It's not that pretty on the back surface but it doesn't show so who cares. Of course, all the cracks still appear on the front. I'm just trying to keep them from expanding and finally failing structurally. Time will tell if it holds up. I did a 200 mile loop yesterday and checked the major crack that reaches the shield edge and it seems sound.
Luckybum
