Wanna buy » Centre Stand Lift Handle
Matt S
2009 1100S (Red)
I have managed to get hold of a centre stand for my 2009 1100!!!
However, I don't have the lift handle. Does anyone know if there is a handle that will fit from another model?
Many thanks.
Matt
Spaceship
2005 1000 DS (Gray)
I wish the stands were easier to find
http://www.ebay.com/itm/Ducati-Multistr ... Rc&vxp=mtr
Looks similar to the 1200's, but not sure if same.
stevedf
The lift handle from an ST2, ST3, ST4, will fit perfectly.
stevedf
the MTS 1200 handle is on the opposite side of the tube, so is backwards for the 1000, 620, 1100.
DMT
Yep, ST2, ST3, ST4 and ST4s grab handles all work. Make sure to get the pin for the grab handle as well.
adamgloe
Resurrecting this thread, as the info was very helpful in helping me to find an ST4 lift handle after I added a center stand on my 1100s. DMT mentioned "get the pin for the grab handle"... I cannot remove the previous and transfer it over. What should I use? Any input appreciated. The 1100s does not have a threaded hole, so a pin has to be forced in as far as I can tell. Just wondering if there is a part number or to bang something in. Standard hex bolts interfere with the lift handle.
Jam23a30
You should be able to source a rolled steel shear pin from your local engineering suppliers.
Seems brutal but get the correct diameter, hammer the thing into the hole and trim to length if required.
Andy
adamgloe
Thank you, that is very helpful!
I will mention here that there is a "Ducati Multistrada 620/1000/1100 Owners UK" facebook group I'm a part of, which is a great bunch and probably the only worthwhile one I know of on that platform. I sourced my center stand from a guy within that group who has several for sale. It came from Poland but was worth the wait and easier than trying to source one online. There are two versions by the way, depending on whether or not your exhaust is catted, or a race exhaust.
Also, the rolled steel shear pin as mentioned above, is illustrated in this center stand article I found after a long internet search. Putting it here for reference.
https://www.webbikeworld.com/ducati-gt1 ... ter-stand/
Cwedish
I use the rail from my Hepco and Becker side cases as handle. However, this has inspired me to look into the STx solution when I get a chance
stevedf
The correct Spiroll pin is an M6x 20. Do not use a split roll pin!
