FireStorm:
re: sssshuddery brakes. Mine had this problem too. I only noticed when I tried to do some rolling stoppies and it started behaving like a concrete mixer on a pogo-stick. I got the mechanic at Bridge in Andover to file off the leading edge of the front pads. This cure dit 100% immediately. I've seen this problem reported elsewhere with much scratched heads, but this was the solution for me, so give it a try.
Rocker:
Good point. I always think 'he who gets there last - still gets there'!
All:
Right more researched facts, to clarify previous questions and comments directed at the Captain, and firm views provoking quotes...
I have about 25 (at least) tests of the R1200GS now. It seems that it's 198 kilo dry and 225 kilo wet. Its 100 bhp at the crank translates (as tmy seat of the pants test stated) to 84.3 bhp and 75 lb/ft of torque, both at the rear wheel. So given the tank tank range and similiar economy it's factual to say that the MS and GS12 have the same power to weight ratio and similar tank range. They both spin quickly like a four, and much quicker than the 1150GS due to light internals and spot on engine management response. The GS has a slight edge in torque over the MS, but to be honest riding them back to back you'd be hard pressed to notice too much. What is clear is that (like the MS) when you look at the dyno charts (source: July '04 Bike, for dyno and weights) the GS12 makes noticeably more power and torque than a KTM950, V-Strom or Caponard right from tickover to 7,000 rpm. And in fact, for instance, at 6,000 rpm it is making more than 10 bhp and 10 lb/ft than it's next nearest rival in the Adventure Sports ( I think enduro-tourer is a better description) category. It also stopped quicker than all of the bikes, from 100 mph it stopped 70 ft quicker than the Prilla! It won that particular test being the most practical, comfortable and best handling on the road. Ergo, it's safe to conclude that performance wise (acceleration, cruising, top speed, braking, power to weight, power per rpm) there's spit difference between the MS and GS. If you want handling, a sportier feel for spirited rides and a Ducati sticker then the MS is an excellent buy. And if you want comfort, practicality, an all-round sprightly tourer and a propellor roundal on the tank then the GS makes an excellent buy too. Either way, for my money, their engaging character and the way they make their power make them the best choices for their respectvie categories, irrelevant of spoilt hacks personal choices. Phew - glad that's cleared up!
