Wanna buy » vibration
mike100m
I took a test ride last friday of about 15 miles.about 50/50 freeway
and secondary roads.I loved the bike.The only problem I noticed was the vibration in the handlebars.I have been riding a Gran Canyon for the
last 2 1/2 years and was surprised to notice this problem on the
MS.The GC has it's bar mounts in rubber bushings and the MS mounts
are solid.Has this been an issue with anyone else? I have no experience with other Ducati models with bar vibration so feedback would be appreciated.
Mike
Bounty
2010 1200S (Black)
Under 3000rpm, the Multistrada certainly vibrates more than my previous bike (a Cagiva Navigator)... but nothing that worries me ;-)
Greg
FE 450 - MTS 1200S
http://www.ArsFabula.com - Mes pages perso
schroell
I don't know of a Duc which is not vibrating.... The vibration causes regularly my right hand to fall aslep!
duc, duc, duc....wroooouuummmm
2016 1200 S (Red)
The easiest cure is this
If the vibration gets annoying - turn up the throttle :D
Noah
Mike,
It's difficult to convey vibration, or rather one's sensitivity to it, via internet. I read and found interesting your comments concerning rod length and the possible effect it has on vibration. If true, and after comparing MS and ST3 engine performance at Ducati.com, then the new 3-valve liquid cooled motor looks like a natural evolution for the MS - as long as there is not a significant weight penalty. I'm sensitive to weight. :)
-Noah
Doc
It's true that vibration is there, but it disappears above 3000rpm. And if you consider how rarely you'll find yourself riding under 3000rpm, then it really isn't something you'll be worried about.
Happy riding,
Doc
THE Multi-DOCTOR
'03 MTS1000DS
PeeBee
Coming from a KTM Duke II, I thought the MTS had an electric engine! It has a very good natural balance: balance that wasn't made with counter balancer shafts etc. A very nice advantage of a 90 degrees V-twin.
I have a 75 degrees V-twin KTM 950 now, and it needs a balancer shaft allright, because it has NO natural balance. As you might guess: a counter balancer will and can not work at 100% effectivity over the entire rev range. result: a rough 'band' between 5200 and 6500 rpm. No such thing on the Multi, as long as you keep it over 3000 rpm. Great engine.
ingo
2012 1200 (Red)
Hi mike, since you had a testride you maybe had a new MTS with less kilometers/miles on it. When i testdrove the MTS in november it had 7000 km's on it, and vibration was no issue for me.
